Solved Fax Server Multiple DIDs
Dbeezy21
Fax Server
888
[email protected]
Inbound rule
DID1
Send to Fax
Extension 101
[email protected]
DID2
Send to Fax
Extension 102
[email protected]
My question is will all of the faxes that come in regardless of the fax DID go to the Fax Server email address ([email protected])? I'd like for them to go to the email address on the inbound rule? Is that possible?
Inbound rules decide where calls go. So if your inbound rule says send fax to that extension, that's where it will go.
So basically the Fax server setting are ignored in this case?
Not ignored if you are routing the call to a specific extension. But it seems pretty easy to test this if you are concerned.
Tested this out and it appears that the DID inbound rules work for the faxes. In this instance it doesn't appear to matter what email address is tied to the fax server. Thanks.
Reactions: NickD_3CX
Kayla Norris
