Solved FDQN Down
maxmm11
my FDQN down please help
How to rest the liecses to add free one please help as it was free but i get a key from a friend now and i want to realese it but i can't as he released it from his portal so the fdqn donw
If the FQDN has been released from the key you are currently using, you can bind a new FQDN by reinstalling.
Just take a backup without the FQDN option ticked, and while installing the new instance select to restore backup. The system will see that there is no FQDN and prompt you to select a new one
i got it thanks i'm already done
You're welcome, glad to hear its done
Kayla Norris
