Feature request: block numbers from ios app
kuitogu
Hello, I would like to request a feature for the ios app to be able to block numbers directly from the call history. At least for the admin user. When I get spam calls I have ti go and login into the portal which is time consuming if I get 3 a day. With this feature it would be much easier
Hello
this isnt the correct way to post ideas.
You will need to be gold and above partner to do so.
https://www.3cx.com/community/forums/3cx-ideas/
Have a browse here and see if anyone has posted before. Otherwise, you could ask a partner to post on your behalf.
DaanLosning
