File not found - Dial by name
RO_
Hi, I configured the Digital Receptionist to use the "Call by Name" feature, but when I tested it, I received a "file not found" error. I checked the forums and saw that updating the system prompts might resolve the issue, but I don’t see an option to do that on my end. The Self ID is already set for the users. For reference, I’m using Version 20.0.
Can you please search for a prompt called 'SELECT_CALL_BY' and let us know if it's there?
If not, kindly open a support ticket for us to advise further.
I dont see it here: 1751046688261.png
Unfortunately, the option for me to create a support ticket is unavailable. Is there any way I can fix this?
Hello RO_,
Try to delete the laguage file, and re-install:
Admin - System - System Prompts - Manage Prompts Sets
Delete the Language you are using
Admin - System - Updates
Klik on the Language to download again
Now the language file is loaded fresh, please try again.
Paulo
I attempted to change the system prompt to a different language and saved it. I opened the system prompt again but the option to delete the standard prompt isn't available
I also don't see an update available for us
Are you loged in as system owner?
As a Silver Partner, you should be able to open a support ticket from your Partner Portal. Can you please check
AshleyStokes
