Firebase Setup updated instructions
cafecom
The firebase instructions that 3cx Links to seems to be out of date. The screens and terminology don't match what I am seeing int he Firebase console. or am I looking at the wrong things.
I have tried to setup and took a guess as to the details I needed (screenshot attached), however is it possible to test the Google Push connection?
Yes. Close then make a call. If it works, push is working.
I'm not sure how to test it, but you can check the log files and look for PUSH messages.
Code:
root@3cx:# grep 'PUSH' /var/lib/3cxpbx/Instance1/Data/Logs/3cxSystemService.log
2019/08/29 14:48:03.050|13805|0066|Info|Sending PUSH to extension 9889 device iPhone10,4; iOS 12.4iPhone
2019/08/29 14:48:03.361|13805|0066|Info|PUSH request is sent succesfully. No errors received
2019/08/29 15:35:20.095|13805|0079|Info|Sending PUSH call-started for dn=9892, replaces=yAfTQRoM2gJKA2Cw6BDNIg..;from-tag=4c2ac635;to-tag=f017fb22, callerid=MakeCall, callername=MakeCall, callid=1660
2019/08/29 15:35:20.095|13805|0079|Info|Sending PUSH to extension 9892 device A-gold S3_Pro
2019/08/29 15:35:23.827|13805|0079|Info|Sending PUSH call-ended for dn=9892, replaces=yAfTQRoM2gJKA2Cw6BDNIg..;from-tag=4c2ac635;to-tag=f017fb22, callerid=MakeCall, callername=MakeCall, callid=1660
2019/08/29 15:35:23.827|13805|0079|Info|Sending PUSH to extension 9892 device A-gold S3_Pro
[email protected].
