Solved Firefox audio output device
Sepultura
Forum User
most of my users are using Firefox on Windows 10. When using the web client they cannot change the audio output device because it is limited to the Windows standard device. Is this a limitation of Firefox/Windows or may this change in the future?
Using Edge (Chromium) the setting can be changed.
Hi this is a limitation with Firefox, you can only use the default windows output for WebRTC calls (which is what we use).
On Chrome you can choose manually though.
Reactions: Sepultura
gmacinit
