cam Customer Joined Apr 3, 2019 Messages 133 Reaction score 20 Jun 18, 2020 #1 Hi We have 3cx running on Azure using the 3cx template, it is running the latest version of 3cx it works Ok apart from the push notification not working on a mobile phones But it fails the firewall check as per attachment, Any ideas. Attachments 1592468322304.png 104.9 KB · Views: 16
Clément Rousseau Titanium Partner Advanced Certified Joined Dec 10, 2018 Messages 180 Reaction score 54 Jun 18, 2020 #2 we need more infos to help you, you only show some ports fails but ALL others works ? Reactions: cam
cam Customer Joined Apr 3, 2019 Messages 133 Reaction score 20 Jun 18, 2020 #3 Sorry, yes all other ports are OK
Alphabetic 3CX MVP Silver Partner Advanced Certified Joined Jul 1, 2016 Messages 6,681 Reaction score 2,668 Jun 18, 2020 #4 Have you checked the firewall rules in Azure? Which mobile devices are not receiving push? Reactions: cam
cam Customer Joined Apr 3, 2019 Messages 133 Reaction score 20 Jun 18, 2020 #5 Yuo were righ! I forgot to allow the ports, I assumed the Template set everything. I am all green now! thanks
