Firewall Checker versus IPS
LtFrankDrebin
Hello community!
I have a 3CX Pro System running with all firewall rules set up.
During setup (months ago!) i checked communication using firewall checker and everything was fine then.
Now we have audio problems in some outgoing calls (call connected but no audio).
I rerun the firewall checker and i get error "full cone test failed" now on some SIP RTP ports (UDP 9000 - UDP 9500).
My questions are:
1:
I don't have "PBX delivers audio" option set in extensions, but could this be the reason for the audio problem nevertheless?
2:
Firewall guy says, the "full cone test failed" error is provoked by the 3CX firewall checker, because the intrusion prevention system is classifying the check as an attack and is blocking the IP then.
Anybody had issues with IPS when running 3CX firewall checker before?
Is 3CX firewall checker imitating normal SIP communication or is it just a port scanner?
Any help appreciated!
Regards
Andreas
1:
Are you using a SIP trunk or a gateway? Do you have audio issues with internal calls as well?
2:
Please see the following article that explains how the firewall checker works but the short answer is that Yes the firewall checker could trigger the intrusion prevention system however most firewalls have sensitivity settings to control this.
https://www.3cx.com/docs/firewall-checker/
Thx for the link to the article, i read it before but could not figure out if the firewall checker sends payload or does "simple" scans.
We have a bunch of SIP trunks (17).
As far as users report audio issues (no sound when connected) happen intermittently both on internal and external calls.
For some users reporting the issue i activated the option "PBX delivers audio" just to check. I was just informed that there's no improvement...
Any ideas what i can do now?
Your help is very appreciated!
A few details regarding the installation would be useful so we can better understand the issue. Is the PBX local or remote? What devices are you using and how are the devices provisioned?
Is the issue random or does it happen with specific sip trunks or specific extensions? What version PBX are you running?
Hi YiannisH_3CX,
Version is 15.5.10244.4 Enterprise (on premise with NAT traversal).
Windows 3CX Client is v.4 (for support and customer service teams).
Provisioning:
  • Network interface for registration and provisioning is the 3CX FQDN.
  • SIP Transport is configured UDP
  • RTP Mode: Normal
  • DTMF Mode: RFC2833
  • Enable PUSH for smartphones: enabled
  • Re-provision phone on Startup: Enabled
  • Use 3CX Tunnel for remote connections: enabled
  • Codecs order for extensions:
GSM-FR
G729
G.711 U-law
G.711 A-law
G722​
The issue is unfortunately random but accumulating.
Does this information help you more?
Is this the build number of the clients? You can see their exact build number if you navigate to Settings / Advanced settings / About.
You are only using 3CX clients?
I could reproduce strange behaviour today myself.
Called out from 3CX Prod Server Extension via SIP trunk to an extension on another 3CX Test Server.
Caller calls, phone rings, everything ok.
Next time the phone rings only one time then stops ringing, call on both sides ends.
Another time phone does not ring on callees side, caller is forwarded to mailbox.
Found some mysterious 404 not found and timeout entries in log (while always calling the same destination number), see log file here when the caller is rerouted to the mailbox:
<begin log files>
Callers side (originating system)
22.06.2018 09:51:56:499 | [CM503001]: Call(C:47): Incoming call from Extn:<ExtensionNumber> to <sip:<TargetNumber>@<Name.3CX.tld>:5060>
22.06.2018 09:51:56:499 | [CM500002]: Call(C:47): Info on incoming INVITE from Extn:<ExtensionNumber>:
Invite-IN Recv Req INVITE from 127.0.0.1:5080 tid=Pjb96c032694a24d80934358dfca4825fa Call-ID=99b9f9e78e7b49a5b64b886327235a12:
INVITE sip:<TargetNumber>@127.0.0.1:5060;transport=UDP;tag3cx=be4795dd13474c4199b08e332267c01a SIP/2.0
Max-Forwards: 69
Record-Route: <sip:[email protected]:5080;user=proxy;uri=clnt.1-965c6299bd1946128421016dee1cbd8a>
Contact: "<From Name>" <sip:<ExtensionNumber>@127.0.0.1:5060;rinstance=1-965c6299bd1946128421016dee1cbd8a>
To: <sip:<TargetNumber>@<Name.3CX.tld>;tag3cx=be4795dd13474c4199b08e332267c01a>
From: "<From Name>"<sip:<ExtensionNumber>@<Name.3CX.tld>>;tag=fff55e8e240046159297d559a1a242bd
Call-ID: 99b9f9e78e7b49a5b64b886327235a12
CSeq: 6480 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Content-Type: application/sdp
Proxy-Authorization: Digest username="if96e7c",realm="3CXPhoneSystem",nonce="414d535c113d3b9c69:218663e09e8f823c045944f59ea86d77",uri="sip:<TargetNumber>@<Name.3CX.tld>;transport=tcp;tag3cx=be4795dd13474c4199b08e332267c01a",response="3b0ff4fa0c689dcdcbfb40177bf18163",algorithm=MD5
Supported: replaces, 100rel, timer, norefersub
User-Agent: 3CXPhone for Windows 15.5.12227.5
Content-Length: 425
v=0
o=- 3738649914 3738649914 IN IP4 192.168.1.26
s=pjmedia
c=IN IP4 127.0.0.1
b=AS:84
t=0 0
a=X-nat:0
m=audio 11052 RTP/AVP 3 18 0 8 9 96
c=IN IP4 127.0.0.1
b=TIAS:64000
b=AS:84
a=sendrecv
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
m=video 0 RTP/AVP 31
c=IN IP4 127.0.0.1
22.06.2018 09:51:56:500 | [CM505001]: Endpoint Extn:<ExtensionNumber>: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Windows 15.5.12227.5] PBX contact: [sip:<ExtensionNumber>@127.0.0.1:5060]
22.06.2018 09:51:56:500 | [CM503010]: Call(C:47): Making route(s) from Extn:<ExtensionNumber> to <sip:<TargetNumber>@<Name.3CX.tld>:5060>
22.06.2018 09:51:56:500 | [Flow] Target endpoint for <TargetNumber> is Out#:>>Rule{<TrunkRuleName>}>><TargetNumber>
22.06.2018 09:51:56:500 | [Flow] Call(C:47): has built target endpoint: Out#:>>Rule{<TrunkRuleName>}>><TargetNumber> for call from L:47.1[Extn:<ExtensionNumber>]
22.06.2018 09:51:56:500 | Call(C:47): Call from Extn:<ExtensionNumber> to <TargetNumber> matches outbound rule '<TrunkRuleName>'
22.06.2018 09:51:56:500 | Line limit check: Current # of calls for line Lc:10003(@sip Trunk[<sip:<TrunkMainNumber>@<VoIPProviderFQDN>:5060>]) is 0; limit is 64
22.06.2018 09:51:56:500 | [CM503004]: Call(C:47): Route 1: from L:47.1[Extn:<ExtensionNumber>] to T:Line:10003>><TargetNumber>@[Dev:sip:<TrunkMainNumber>@<VoIPProviderFQDN>:5060]
22.06.2018 09:51:56:500 | [CM503027]: Call(C:47): From: Extn:<ExtensionNumber> ("<From Name>" <sip:<ExtensionNumber>@<Name.3CX.tld>:5060>) to T:Line:10003>><TargetNumber>@[Dev:sip:<TrunkMainNumber>@<VoIPProviderFQDN>:5060]
22.06.2018 09:51:56:529 | [CM503025]: Call(C:47): Calling T:Line:10003>><TargetNumber>@[Dev:sip:<TrunkMainNumber>@<VoIPProviderFQDN>:5060] for L:47.1[Extn:<ExtensionNumber>]
22.06.2018 09:51:57:147 | [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
Invite-UNK Recv Req INVITE from <VoIPProviderPublicIP>:5060 tid=e6a1116aa990530a61f95f2676e95a2d Call-ID=yoLSB8QBEKbQ0xEW_v26VA..~2o:
INVITE sip:<InviteSIP>@<3CXPublicIP>:5060 SIP/2.0
Via: SIP/2.0/UDP <VoIPProviderPublicIP>:5060;branch=z9hG4bK-524287-1---e6a1116aa990530a61f95f2676e95a2d;rport=5060
Via: SIP/2.0/UDP <VoIPProviderPublicIP>:5071;branch=z9hG4bK-uyyh74waod56zpys;rport=5071
Max-Forwards: 69
Record-Route: <sip:<VoIPProviderPublicIP>:5060;transport=udp;lr;pinhole=UDP:<3CXPublicIP>:5060>
Contact: <sip:<VoIPProviderPublicIP>:5071>
To: <sip:<TargetNumber>@<VoIPProviderFQDN>>
From: <SourceDID> <sip:<SourceDID>@<VoIPProviderFQDN>>;tag=il7r5vwczh62i7ho.o
Call-ID: yoLSB8QBEKbQ0xEW_v26VA..~2o
CSeq: 652 INVITE
Expires: 300
Allow: INVITE, ACK, BYE, CANCEL, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS, UPDATE
Content-Disposition: session
User-Agent: Sippy
h323-conf-id: 2971849412-961481925-4226754372-4226754372
cisco-GUID: 2971849412-961481925-4226754372-4226754372
Content-Length: 252
v=0
o=Sippy 1208912196286077236 1 IN IP4 <VoIPProviderPublicIP>
s=3cxPS Audio call
t=0 0
m=audio 9072 RTP/AVP 0 8 3 101
c=IN IP4 <3CXPublicIP>
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=sendrecv
22.06.2018 09:51:57:534 | [CM503002]: Call(C:47): Alerting Line:10003>><TargetNumber> by contact <sip:<TrunkMainNumber>@<VoIPProviderFQDN>:5060>
22.06.2018 09:51:57:534 | [CM505003]: Provider:[SIP Trunk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:<TrunkMainNumber>@<3CXPublicIP>:5060]
22.06.2018 09:51:58:766 | L:47.2[Line:10003>><TargetNumber>] has joined to L:47.1[Extn:<ExtensionNumber>]
22.06.2018 09:51:58:767 | [CM503007]: Call(C:47): Extn:<ExtensionNumber> has joined, contact <sip:<ExtensionNumber>@127.0.0.1:5060>
22.06.2018 09:51:58:767 | [CM503007]: Call(C:47): Line:10003>><TargetNumber> has joined, contact <sip:<TrunkMainNumber>@<VoIPProviderFQDN>:5060>
22.06.2018 09:52:09:489 | Leg L:47.1[Extn:<ExtensionNumber>] is terminated: Cause: BYE from 127.0.0.1:5080
22.06.2018 09:52:09:489 | [CM503008]: Call(C:47): Call is terminated
Callees side (target system)
22.06.2018 09:51:57:708 | [CM503003]: Call(C:28): Call to <sip:<ExtensionNumber>@<TargetCustomer.3cx.tld>:5060> has failed; Cause: 404 Not Found/INVITE from 127.0.0.1:5080
22.06.2018 09:51:57:708 | Call to T:Extn:<ExtensionNumber>@[Dev:sip:<SIP>@127.0.0.1:5060;rinstance=1-r0taqqj0mzuvthqdpdmuo5z.-lruoors;inst="d04d0359",Dev:sip:<SIP>@127.0.0.1:5488;rinstance=1f1afc9c172e9b9c] from L:28.1[Line:10003<<<FromNumber>] failed, cause: Cause: 404 Not Found/INVITE from 127.0.0.1:5080
22.06.2018 09:51:58:433 | [CM503003]: Call(C:28): Call to <sip:<ExtensionNumber>@<TargetCustomer.3cx.tld>:5060> has failed; Cause: 408 Request Timeout/INVITE from 127.0.0.1:5488
22.06.2018 09:51:58:433 | Call to T:Extn:<ExtensionNumber>@[Dev:sip:<ExtensionNumber>@127.0.0.1:5488;rinstance=1f1afc9c172e9b9c] from L:28.1[Line:10003<<<FromNumber>] failed, cause: Cause: 408 Request Timeout/INVITE from 127.0.0.1:5488
<end log files>
How come the target is found some times some times not?
Bastion Advisory
