Solved Firewall ports for V20 - Undocumented change
Dominique_CH
SMB User
According to current 3CX documentation, the ports to open inbound didn't change from V18 to V20, in particular Ports 9000-10999 (inbound, UDP) for RTP (Audio) communications.
However, performing a firewall check on V20, the tested range has been increased to 9000-18998. Of course, the firewall check fails unless the range is extended.
Does anybody now what the range 11000-18998 is used for if not for RTP? Or is it just a missed update in the documentation?
https://www.3cx.com/docs/manual/firewall-router-configuration/#h.si5w65z91x7o
Sorry for this misreading on my side: the RTP-ports didn't change, it's more a number-display issue where the 0 looks like 8 :mad:
Based on your screenshot it seems that it is very easy to get confused:)
Teemal
