Firewall Setup
lodge
Since upgrading from v16 (which seemed to go well) users complaining of one way audio on inbound calls. Internal and outbound are fine. Finally figured out that switching off the IVR and making all phones ring in a ring group got round the problem. However user then report that 1 way audio happens when transferring calls, which is presumably why the IVR was broken. Any thoughts?
in the logs:
16/08/2021 16:34:59 - [CM503003]: Call(C:180): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 10.0.96.29:65179
16/08/2021 16:34:57 - Exception: DialogUsage::Exception Can't provide an answer @ ServerInviteSession.cxx:501
Ok, so you have NO AUDIO, that is a different issue than the OP.
In this case, please create a new thread so that we don't mix things up.
OK if I expierence issues I will open a thread
Thank You
Reactions: NickD_3CX
laranicole.lucus
