Firmware update through console
Toddalex2000
If i select an extension and push firmware from the 3cx console i get the popup that tells me the firmware request has been sent...
Nothing happens afterwards. is it a provisioning issue? any idea?
The below IP Phones will be upgraded to the latest firmware version. The phones will be unavailable during the upgrade and might reboot several times.
ModelDevice VersionAvailable VersionInformation
Yealink SIP-T46G 28.80.0.130 28.83.0.55 Yealink T46G FW: SP5 or higher version is required!
Yes, the 28.80.0.130 firmware version does not have the ability to receive the firmware push because anything older than XX.83.0.55 wll have an outdated SSL certificate for 3CX. Once you do a manual update, you'll be able to push subsequent updates.
RicoDinero
