anog10 Customer Joined Feb 21, 2022 Messages 16 Reaction score 0 Feb 21, 2022 #1 I try to update manually image for Fanvil X5U. Is write me invalid image and not upgrade continue.
Alphabetic 3CX MVP Silver Partner Advanced Certified Joined Jul 1, 2016 Messages 6,627 Reaction score 2,640 Feb 21, 2022 #2 Where are you pulling the FW from?
anog10 Customer Joined Feb 21, 2022 Messages 16 Reaction score 0 Feb 21, 2022 #3 From webinterface upgrade i select the img (extracted from rar)
Alphabetic 3CX MVP Silver Partner Advanced Certified Joined Jul 1, 2016 Messages 6,627 Reaction score 2,640 Feb 21, 2022 #4 You need to use the firmware from here https://www.3cx.com/support/phone-firmwares/
Saqqara Bronze Partner Basic Certified Joined Mar 12, 2014 Messages 4,775 Reaction score 1,471 Feb 21, 2022 #6 Follow these steps - not sure if you have to expand the file https://www.3cx.com/sip-phones/firmware-update-fanvil/
anog10 Customer Joined Feb 21, 2022 Messages 16 Reaction score 0 Feb 21, 2022 #7 is ok this is issue. i don't have to extract it. thanks
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,546 Reaction score 3,716 Feb 21, 2022 #8 Hi, Do not extract the file, it must be used as-is. Please confirm if this worked for you now.
