Solved First Time Setup - Unable to make outbound calls
RoyJ
New User
I tried to post this in the hosted section, but it wouldn't let me even though I have a hosted system
I can receive calls fine, but when I make an outbound call, the report shows no route exists, even though there is one. What am I missing here?
I am using Flowroute
Thank you in advance,
Roy
For one, Flowroute requires calls in E164 format, so you need to prepend 1 if you are doing 10 digit dialing in your outbound rule.
Second, your extension is in the department that you crossed out? And you are dialing a 10 digit number?
If you remove the digit length and add the Department, do you still experience any outbound call issue?
in your screen copy Outbound rule is set with 10 digits only numbers so if you dial more or less than that no rule will apply so no outgoing call
Reactions: RoyJ
Thank you, prepending 1 solved the issue! I knew it had to be something minor.
Yes, my name is in the department's list. Should it not be?
@RoyJ
Perfect and thank you for the feedback provided.
Glad to know this is resolved ;)
streamservices
