Solved Flowroute : 407 Proxy Authentication/E164 format
SFRAZ1
Hello, Everyone I have a small problem, My client was using a 3cx with the management console and everything was fine as we used *480XXXXXX instead of +1480XXXXXXX in the DID section of the trunk.
now we are using an SMB for the client and in SMB we don't have the option to add * we have to use +1 in the field.
I called Flowroute and using a test environment we found out that if we use +1 in the 3cX with the management console it gives the error 407 Proxy auth error and the call never gets a tone.
No bother at all, glad that this is working for you.
Regarding your question, there are no outbound rules to modify in 3CX SMB. These are created automatically and are created to pass any calls made from the extensions in your group.
Additionally, the call will be passed with any numbers that are dialed, so you may need to check with the provider whether they will accept or not.
