Flowroute Call Formatting issue
healthy
A few weeks ago, I had an issue where all of our calls are routed to the main number if the SIP trunk DIDs are in +1... format. If I re-populate as 3CX Requires, my calls no longer route to the proper DIDs.
I reached out to Flowroute support and they tell me they cannot format the calls any differently, and that I must reformat the inbound numbers to prepend the + in front of the number. I don't see anywhere to do this in my system.
Hi there.
Can you show us an example of the working scenarios and the one that does not work?
Also, if you run the capture, do you see the numbers entered in the exact same way as the provider sends them to you?
Reactions: MiraG_3CX
Sure, I just ran the call test. Outside phone number to a DID which fowards to my extension:
Made with our number without the leading + - Call routes properly to the extension (111 in this case)
4/23/2024 5:34:28 PM - NAT/ALG check:L:133.1[Line:10000<<OUTSIDENUMBER] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
SIP proxy detected:
Record-Route:<sip:35.173.62.45:5060;lr>
Record-Route:<sip:34.226.36.35:5060;lr;did=9e21.2762>
Media session IP ('c=' attribute) is not equal to the SIP packet source(IP:port):
Media session IP: 207.223.67.137
Received from: OUR_PBX_IP
04/23/2024 5:34:27 PM - NAT/ALG check:L:133.1[Line:10000<<OUTSIDENUMBER] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
SIP proxy detected:
Via:SIP/2.0/UDP 34.226.36.35:5060;branch=z9hG4bKa3bb.ee898a83c6b20b270dfa44e7402e17cd.0
Via:SIP/2.0/UDP 54.71.6.127:5060;branch=z9hG4bKa3bb.e4e692497cfa346c0a5b910215218d3c.0
Via:SIP/2.0/UDP 35.173.62.45:5060;branch=z9hG4bKa3bb.eada3407208189c098e6f9338e68488f.0
Via:SIP/2.0/UDP 207.223.78.224:5060;branch=z9hG4bK00B0b2f430501936877
Received from: 34.226.36.35
04/23/2024 5:34:17 PM - [CM503003]: Call(C:132): Call to <sip:111@OUR_PBX_INTERNAL_IP:0> has failed; Cause: 487 Request Terminated/INVITE from 192.168.60.125:5060
04/23/2024 5:34:14 PM - [CM503003]: Call(C:132): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
Re-tested with + in front of the number inside of the SIP Trunk
04/23/2024 5:39:13 PM - [CM100002]: *!* Exception detected: unknown *!*
04/23/2024 5:35:26 PM - [CM503003]: Call(C:134): Call to <sip:111@OUR_PBX_INTERNAL_IP:0> has failed; Cause: 487 Request Terminated/INVITE from MY_DESKPHONE_IP:5060
04/23/2024 5:35:25 PM - [CM503003]: Call(C:134): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5483
04/23/2024 5:35:22 PM - NAT/ALG check:L:134.1[Line:10000<<OUTSIDENUMBER] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
SIP proxy detected:
Via:SIP/2.0/UDP 34.226.36.35:5060;branch=z9hG4bKd571.375ecb8000d93f9c9b575884ef4c9f9c.0
Via:SIP/2.0/UDP 54.71.6.127:5060;branch=z9hG4bKd571.81cbf8d079e58025aeb94b8b2f4c47da.1
Via:SIP/2.0/UDP 34.211.68.10:5060;branch=z9hG4bKd571.dc30765385564b5a558df34b0cb7123b.0
Via:SIP/2.0/UDP 207.223.78.224:5060;branch=z9hG4bK0cBc54de552cb871f84
04/23/2024 5:34:28 PM - NAT/ALG check:L:133.1[Line:10000<<OUTSIDENUMBER] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
SIP proxy detected:
SIP proxy detected:
If possible open the ticket with us so we can check the logs and take it from there
SG_F7
