Flowroute SIP Trunk Settings
Frank86
Is this page still applicable to Flowroute under 3CX 15.5?
https://support.flowroute.com/customer/en/portal/articles/2959803-configuring-a-3cx-trunk
My configuration under step 6 is very different from the above page.
The URL’s step 6 recommends the following:
  • Put Public IP in SIP via Header (I don’t have that selected)
  • Force Invites to be send [sic] to the IP of Registrar (mine is deselected)
  • Re-Register timeout: 600 (mine is 120)
  • Select which IP to use in ‘Contact’ (SIP) and ‘Connection’ (SDP) fields (mine has “Use Default Settings”)
Under inbound parameters, I have
  • To:User Part
Instead of what is recommended under step 7 at the URL above:
  • P-asserted identity: user part
  • Request line URI: user part
  • P-asserted identity: display name
Then, under Options > Codec Priority, I have the following (I don't want Flowroute to use G729, so I removed it):
  • G.711 U
  • G.711 A
Thank you.
Reactions: Frank86
Texas Clay -
