Force M365 contacts sync NOW
David_K
Hello
If I'm right, the M365 sync does occur once per day?
Is it possible to force a sync NOW ?
Or at least to see/change the hour when the sync occurs?
Thanks.
Actually it syncs two ways:
Daily at midnight.
And
Whenever there is a change in O365, 3CX will receive a real-time notification and the contact will appear in the Webclient pretty quickly.
Initial sync is also on the spot usually.
Reactions: VoIPTools
Daily at midnight.
And
Thanks @ConceptsWeb
So each time for instance someones adds or edits a contact in his M365 account, the contact will be added/updated ?
FYI, You may also force a sync by restating the 3cx system server service
