force night mode
sergen
Platinum Partner
I am using 3cx hosted v18 with update 5.
I have gone to advanced settings dial codes and set the "Force 3CX Phone System to IN or OUT of office" to *90.
but when I dial *90 it just gives me the status of what mode we are in.
how do I force it to go to night mode or remove the night mode?
You can use the dial codes and force the PBX into the Out of office hours by dialing the code, and all the incoming calls will be sent to the configured destination in your rule.
Remember that if you use that option, you will need to switch the PBX back to the default state, as PBX will not auto-switch back when it is available or Out of office hours. If your Dial code is *90, use the following: *902 for Out of office hours *901 for In office hours *90 or *900 for the Default hours
Thank you. Case resolved.
We are glad to be of assistance.
TVV40
