Fortigate SIP ALG Removal Update
AverageAs
Hello All
Just an update to an old thread I had done for newer versions of firmware. Caught me out the other day.
To Disable SIP ALG follow the below steps
Backup your firewall config first!
For FortiOS 6.2.2 and above
config system settings
set sip-expectation disable
set sip-nat-trace disable
set default-voip-alg-mode kernel-helper-based
end
For FortiOS below 6.2.2 ( 6.2.0 down to 5.2.0 )
set sip-helper disable
end
The rest is the same as I previously posted
Locate SIP entry in session-helper list and remove it
config system session-helper
show
Look for the entry SIP (normally 13) SIP, If found enter the below command
delete 13
end
Next disable processing of the RTP Protocol
config voip profile
edit default
config sip
set rtp disable
end
end
Once complete it is best to reboot the router to clear sessions on the 5060 protocol.
If you are having issues with phones registering reboot both firewall and the phones.
WAFI
