Forum Help, 3CX or Server Help??
TBWD
Forum User
I am seeing tons of posts that are more server related than 3CX related. A PBX administrator is not the same as a Server administrator, that role should only be done by a qualified person. I believe if you don't know how to properly run a server you should hire someone that can. Although many issues may seem small, getting into the server can make it much worse.
What small issues are to some, are bigger issues for others. I wouldnt begrudge anyone who came here looking for support with their 3CX when the issue is server related. though, 3CX alone isn't a PBX is it? It needs hardware to run, so, you must support everything else that makes it work providing of course it's within the scope of 3CX's support requirements. 3CX is very simple and very well documented that even the home user can get a PBX set up. But, from time to time everyones needs a hand. If they didnt, there would be no need for "Senior Support Technicians" like you and me.
Reactions: complex1
[email protected].
