forward all vms to another mailbox automatically
BABALUCHA
Hello Everyone
Hope everyone is doing well. Thanks for stopping by and pitching in . Quick question , how can i forward all the voicemail messages from one extension's mailbox to another extension's mailbox automatically ? i told the customer these options below but they still insist me to find a way to through into 2 mailboxes .
Option 1 Send it to an email so whoever has access to that email can check the message.
Hello @BABALUCHA that would be the workaround, directly use a distribution email address and implement it on the extension, so VM to email will be sent to that address and the users can check the message.
Another option is just adding a ring group or call queue with those extensions, then you can forward the calls to the Group VM and the agents in that group will receive an email with the notification.
Have a great day!
If the standard group email is not sufficient, you may want to take a look at our 3CX Voicemail Manager tool. With our tool you have several options: (1) automatically escalate unheard voicemails to a manager, or (2) use our enhanced group voicemail that not only forwards as an email, but also duplicates the voicemail in each group member's voicemail box (turns on the MWI on your phone), or (3) provide managers direct access to the voicemails of people they manage through a simple web interface from anywhere...
AshleyStokes
