forward to ring groups
Tit-Neu
Hello all,
is it possible to set that the users themselves can forward to ring groups? Unfortunately, the users themselves can only forward to individual extensions via Desktop-App. If forwarding to a ring group is necessary, we in the IT department have to do this via the management interface.
Thank you very much.
Hi @Tit-Neu,
From the Desktop App of the extension >> Settings >> Call Forwarding you can set the destination if no answer of the status profile that you want to be a ring group or a Call Queue. You will have to set the destination forward to 'System Extension'.
Unfortunately, only 700 and 999 are displayed for the system extension. The ring groups we have created are not listed. Do we have to adjust this somewhere?1688996675696.png
@Tit-Neu
Go to Management Console >> Settings >> Options and check if option "Hide System Extensions (IVR, RingGroup, Queues and FAX) from 3CX Apps Company Phonebook" is enabled.
If so, disable the option and let us know.
Reactions: Ecki and Tit-Neu
Oh my God, thank you. That worked. That makes things a lot easier.
imelda
