Forwarding calls need to show original caller ID
jkampwerth
Is there a way to have a forwarded external call show it's caller ID as opposed to the caller ID of the extension that forwarded it?
So our receptionist receives a call, then she forwards it to customer service. We want the callee's caller ID to show instead of the receptionist's.
Any help is appreciated.
Thank you
Hi jkampwerth,
There are a number of factors that may play a part in what is shown as the Caller ID of a call, but first and foremost is the SIP Provider and the SIP Trunk's configuration within 3CX.
Which SIP Provider are you using, is it a 3CX Supported SIP Provider?
Basically your SIP trunk needs to support spoofing a caller ID (usually noted as "Clip No Screening") - if it doesn't, you are limited to the outbound numbers you have with their system.
If they do, it's usually as simple as modifying a trunk parameter (it varies on the provider but ones to look at are "From: User Part" and "Remote Party ID - Calling Party".
Naveen's question is correct. We need to know who to advise further.
Our SIP provider is CallTower
Any other help is appreciated.
Have you reached out to CallTower to ask them if they support Clip No Screening?
Thank you for that. I'm still awaiting a response from Calltower's support.
gmacinit
