FQDN Issue and SSL
Laramee & Theroux
After reinstalling in AWS, our FQDN (Which was released before in the partner portal) and then reinstalled from a back up. Is not working.
SSL as well has not been renewed...
Did you make sure not to include license key / fqdn when you restored from backup?
If you restore an old fqdn setup to a system where the fqdn has been released and / or re-registered at install you are going to have these sorts of problems.
You might like to take a look at this thread - it refers to PBXpress but, I think, would still apply:
https://www.3cx.com/community/threa...-instance-using-pbx-express-best-steps.61917/
Why did you release your FQDN? Did you use a different licence key or a different FQDN? Did you use PBX express to install the system?
estrezacafe111
