FQDN not resolving both Dynamic and static IP
ThaboZ
Help please
Can anyone please assist with 3cx configuration for Fortigate Firewall.
The DNS record is not updating and the Firewall checks are failing even though I have opened all the necessary ports.
The SIP server is sitting locally behind the Firewall which is on NAT mode, can anyone advise how to go about configuring the Fortigate.
I have disabled the Sip helper and configured the SIP ALG to - 'set default-voip-alg-mode kernel-helper-based'.
I removed the SIP session helper and configured it as below.
set sip-nat-trace disable
Please advise if the any other configuration I need.
For local extension both inbound and outbound calls are working but the softphone apps are not even registering.
This is my first configuring a Fortigate Firewall.
Please help!!!
I am getting the below errors from the SIP server so I am not sure why.
Please assist
Hello @ThaboZ,
You mentioned 3 seperate problems above, let's start with just one: Firewall Checker failed. Have you followed this guide and can follow it once more to ensure it's configured correctly?
Here is a list of the ports used by 3CX to assist you.
Hello VasilisV
Hello @ThaboZ,
Hi VasilisV
Thenk for the response
I have just opened the ports.
OfficeForti # config system setting
OfficeForti (settings) # set sip-helper disable
command parse error before 'sip-helper'
Command fail. Return code -61
I am getting the above error when trying to disable the sip-helper.
I have already deleted the session helper from the list though.
Where do I go from here,
Thank you
Regards
Hi @ThaboZ,
The guide was written a little while back and it may not have been written with your exact model in mind, so at this point the best solution would be to contact a 3CX Partner for assistance.
SupportRock
