Solved FQDN Tied to license - didnt get through install wizard
Alphabetic
3CX MVP
Hello
I've started to go through a new install but instead of finishing, I went back to check settings and it attempted to secure FQDN again but failed and now I cant set this PBX up because the FQDN is tied to the license and I can get any further.
Have you tried releasing the FQDN from the License Key and then try again?
My colleague was doing the setup and I'm not even sure where he registered it.
Can you PM me the first 8 characters of the License Key?
@kieferschild sorted this out in the end by re-attempting the installation.
WAFI
