FreePBX SipStation Question
Amphibian
Hey Team,
I am trying to use the "Sipstation" from FreePBX. When I try to use the module it constantly says "noserver" even when I turn CSF off with no firewall active.
Can't seem to pin point problem. I am able to reach my account at Sipstation through a web browser, according to what Sipstation say that if I can do that then the issue is on my end.
Has anyone used this function (Sipstation) and had success or knows what I need to look for?
amphibian
Are you trying to add the SIP trunk using the Module Keycode or manually? I have done both without any issue, of course this was on FreePBX Distro.
hinzinho,
I was trying to do it through FreePbx using the supplied key, but I said to heck with it and did it manually. All working well now with sip trunks setup and usable.
Thank you sir,
amphibian
