FreshDesk Test Lookup Null Results
CJ Fig
Attempting to setup integration to FreshDesk.
I have a contact with phone number in e164 format, example +15555555555
Testing with the phone number, comes up with nothing. What am I missing? I have tried different number combinations, without the +. Same result.
CRM integration functions properly, but the contact number is not found. Review the log for details or attempt a different number.
Started scenario with empty id
Request text: https://example.freshdesk.com
Response text: []
Response finished
Finished scenario with empty id
Response text: []
Response finished
System > Phonebook > Options, set to Match Exactly.
Thank you! I could not find that option in v20.
3CX needs to update their guide, it says:
Now Go to “Advanced” > “Contacts” > “Options”, set the matching strategy to "Match exactly" and click “OK”.
Yes, that's from a previous version.
