FTP Backup Error - "Path should be not empty"
Peter Richardson
Hi all, please see attached - I can't change the path, it thinks that it's empty. I have tried a few different things but nothing seems to work.
running on Debian 9, 16.0.910
is this a bug?
No idea but if it is, 3CX will tell you to upgrade so I'd start there first.
Thanks @cobaltit I ran all updates before posting. Did I miss something? What's the latest version?
Thanks very much @BrenttG I will investigate that next and get those updates first
Problem solved, thanks guys!!
I needed to run the updates from the command line a couple of times, the second time with apt-get --with-new-pkgs upgrade
Then I was on the latest version and that error didn't appear.
Many thanks!
  • Love
Reactions: BrenttG
travislogixal
