FTP Buckup using Filezilla
aangeles
I have issue setting up my 3CX Cloud Hosted Storage Backup via FileZilla FTP.
I was able to connect the 3CX Cloud to my On-prem Windows using Filezilla but having issue within permission base on log from FIleZilla.
<Date/Time> Info [Type] Message
<05/02/2026 10:07:51 am> File-based Authenticator, FTP Session: 8 [Status] Invoking get_auth_data
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx [Response] 331 Please, specify the password.
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx [Command] PASS ****
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx [Response] 230 Login successful.
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] FEAT
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Response] 211-Features:
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Response] 211 End
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] OPTS UTF8 ON
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Response] 202 UTF8 mode is always enabled. No need to send this command
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] SYST
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Response] 215 UNIX emulated by FileZilla.
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] PWD
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Response] 257 "/" is current directory.
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] TYPE I
<05/02/2026 10:07:51 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Response] 200 Type set to I
<05/02/2026 10:07:52 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] EPSV
<05/02/2026 10:07:52 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Response] 229 Entering Extended Passive Mode (|||55689|)
<05/02/2026 10:07:52 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] MLSD /D:/3CX_Backups
<05/02/2026 10:07:52 am> FTP Session 8 xxx.xxx.xxx.xxxTechnical [Response] 550 Invalid file name or path
<05/02/2026 10:07:52 am> FTP Session 8 xxx.xxx.xxx.xxx Technical [Command] QUIT
<05/02/2026 10:07:52 am> FTP Session 8 xxx.xxx.xxx.xxxTechnical [Response] 221 Goodbye.
<05/02/2026 10:07:52 am> FTP Server [Status] Session 8 ended gracefully.
Generally spreaking the MLSD command is send in order to get the list of content in the directory.
First point is that the directory is /D:/3CX_Backups while it should be D:/3CX_Backups. Also since the connection is there you might need to just add it as /3CX_Backups
This is configuration setting you need to check.
Hi Theo,
Thanks for the response.
Actually that's already define on the FIleZila.
How is it in the PBX side?
Can you please remove the D:\ from the path?
Hi Theo,
I already update the path to " 3CX_Backups " and till I get same error "550 Permission denied"
Then you need to check the permission to the folder. For reference check this guide as well.
ARKC
