FXO Gateway Registration rejected.
ericko
Trial User
Trying to connect a OpenVox iAG series analog gateway to 3CX, continues to fail with the following message in the 3CX Event Log:
SIP request (REGISTER) from XX.XX.XX.XX was rejected. Reason: Block WAN requests is ON
In the same event log we can see a plethora of IP addresses see attached
I don't think you can use a FXO Gateway with 3CX SMB, only dedicated.
Thank you I posted from the wrong log credentials in we do have a 3CX Pro account, should I repost using that system?
I would be best if you use the proper account and proper forum section, that way you are much more likely to get actual relevant advice.
When you repost, please advice how you are trying to make the connection, what config have you added to the 3CX side and what to the Gateway side.
albertpugo02
