Generic SIP trunk
grale
Intermediate Cert.
I have problem to register generic sip trunk
When input all parametar to generic sip trunk, 3cx send to provider litlle confuse registration string.
Can I change manually what register string must send 3cx to provider?
If you state which provider (and in which country), you are attempting to register to, someone also using that provider may be able to help.
You might also want to provide additional information, such as the 3CX Activity Log, and what the provider is telling you.
And what is confusing in the registration string send by 3CX? What do you want to adjust? Also consider using a supported provider which eliminates the need for manual configuration.
https://www.3cx.com/partners/sip-trunks/
