- Joined
- Mar 14, 2018
- Messages
- 29
- Reaction score
- 10
We are using V16 Update 5. Recently I connected two Yealink SIP T49G to our network. Besides being not officially supported by 3CX, those were immediately discovered and correctly displayed in the 3CX phone overview. But I was not able to assign any of those to an extension. The only workaround I found was to select a similar phone within "Extension/Phone provisioning" and do some manual adjustments. Therefore I selected the Yealink T48 as basis, as this is quite similar to the T49G. It worked. BUT: Now, in the extension, it displays "T48" as the extensions phone. This is misleading as it is an T49G and I'm wondering on how this could be renamed.
Is it possible to rename the SIP-phone assigned to an extension?
Why is there not a "generic SIP-phone" entry in the drop down list of available phones that can be used to build upon?
--> In my case I would have selected "generic SIP-phone" instead of "T48", finalize its configuration and then rename it to T49G. Perfect!
I understood from a similar post, that 3CX is moving away from non-supported phones. But looking at new ones like Yealink VP59, those phones are great and provisioning them works. So only renaming does not seem to work, neither does selecting a "generic SIP-phone".
How do you handle such non-supported phones?
Thanks!
Thanks!
