Get 3CX Live Chat and Talk on Any Website
  • Thread starter Thread starter Constantinos Constantinou
  • Start date Start date
Hello
i try to put it on magento2 and i have many javascript conflicts and i start to make a extension
I'm almost ready here is some screenshots
The plugin for magento2 is ready and is work great i make also some translation to my language
this will not work with magento 1.9 isn't it?
Hello @Workbooster_GmbH ,
The javascript code of the Live Chat and Talk is irrelevant to the CMS platform. In cases that implementation is done based on a specific platform, for example, Magento or Joomla, then the wrapper implementation as such should be checked in terms of compatibility and not the javascript.
Yes it is possible. You might have issues with the CORS restriction in that case, but there is a workaround. If you want to configure it, send me a personal message.
Hi! I have CORS issues in my prestashop, I configure the .htaccess to allow it, but it didn't wotks, any solution??
We're not web people so we use SquareSpace for our site.
It was actually pretty easy to set this up for us.
Thanks 3CX.
And a suggestion - it would be nice, if someone requests a chat and no agent is available - that the app would generate an email instead of just the unanswered chat.
How did you get it working with SquareSpace? I've long since abandoned being a website person, so this is foreign to me with a solution like SS. /edit "Computers are hard" gotta throw the JS file onto another host and reference the CSS and JS include in the header portion for SquareSpace.
I think that's not the exact place to query my doubt, but was unable to find a thread that "fits":
I've installed and managed to work with the plugin in my website...
BUT, i need to pass some variables from my website (eg.: name=username and e-mail) from variables actually loaded in the browser window, someone can point me some directions?
Ps.: sorry about my poor english
Right now this is not possible.
However, name and email should be available directly in the plugin window.
Thanks 3CX.
Hi Allen,
We don't use squarespace, but a customer does. Can you provide any insight into the 3cx plugin install process on squarespace.
Thanks,
Dave.
Hi Allen,
Thanks,
Dave.
Hi Dave,
It's been a while since I set this up.
All I have saved in my notes is this -
ONLY need to paste code into footer CODE section
The code referenced is that generated in the management console
Settings
Wordpress/Website Integration
Website Code Generator
after filling out the relevant information on both tabs.
If this isn't enough to help get back to me and we can look a little further.
Reactions: David Forster
Hi Dave,
Settings
Super thanks, I'll give that a try :)
I am also trying to set up in wix and cannot as 3cx requires a JS file and wix wont allow that. Most chat involved a simple html code be added, why is this more complicated? With tens of thousands of wix websites made, there must be a solution surely?
Hello @NEIL DEVONPORT ,
Soon we will have the option to support CDN on the code-generator. With this approach it will be straight forward to configure it on Wix.
what does 'soon' mean, in my experience that is no time soon. More importantly, what interim solution are you providing?
By soon I mean begining to mid of next month :)
Reactions: accentlogic
and a workaround?
Since they are not allowing uploading JavaScript files, only your private CDN subscription/webserver is the workaround.
Hi, do you have the extension available for Magento2?
sherry reynolds
