get phonenumber and send to api server
zimmic
i am using 3cx free for testing.
Is it possible to get a incoming phonenumber of a person that calls and the 3cx server then send the phonenumber to an api server?
And if that is possible how to get it done.
Thanks in advance for any reply.
Mick
With the free edition this is not possible.
with a Professional or enterprise dedicated instance you are able to integrate with a CRM and send the number and call information to this server.
Thanks for you quick answer.
I will look at the Professional version.
Mick
LeeonLau
