Getting error file scheme not supported when testing CRM integration with Zoho
TimoM
I have a 3cx V20 integrated to Zoho CRM and was working. Later the client ID was deleted and re-created on Zoho side. Now integration test gives error "The 'file' scheme is not supported.".
Anyone seen this before?
Regards
Tim
Make sure your URLs are properly configured and that you're using the latest template for Zoho.
Regards
Tim
Thanks for this. Any idea how to confirm the latest template for Zoho?
Regards
Tim
Hi Tim,
The latest version of the template is 35, you can find the version by navigating to Admin >> Integrations >> CRM >> Show Template.
Can you also clarify how did you delete the client ID from Zoho? Did you delete the whole project and recreated it? If so was the correct application selected (i.e. Server-based application)
