GHL
oussama
New User
i did create template in 3cx wizard and app in marketplace of GHL when i tried to test the integration i got this error
Server returned a non successful status code - HTTPStatusCode=UnprocessableEntity - Reason=Unprocessable Entity - Content={"message":["client_id should not be empty","client_secret should not be empty","refresh_token should not be empty"],"error":"Unprocessable Entity","statusCode":422,"traceId":"fe7311a1-4371-4370-8676-74686dbe9e6b"}
It looks like you're not doing the authorization. All your settings are empty.
I'm not sure what this is. What I can tell you is that 3CX is trying to get the access token for OAuth2, and to do that it needs the client_id, client_secret and refresh_token, and none of them are set. The client_id and client_secret should be set by you while configuring the integration. The refresh_token is obtained during the authorization phase in OAuth2, which seems you're not running.
