Give user CID choice via dropdown
Telecomlijn
Gold Partner
I am aware of the fact I get a user to dial out with an alternative CID by adding a prefix, but would really like to see the option of being able to give each extension a choice of CID's by for example presenting a dropdown with the the CID's. This would enable the user to use clicktodial after selecting the proper CID, which is impossible now.
The 3CX administrator determines which extension is able to use which CID, but it makes life so much easier then creating extra trunks for every CID.
Maybe there's a solutions or a workaround of which I am not aware?
Take a look at our Caller ID tool.
https://www.voiptools.com/product/3cx-caller-id-new/
This is a simple-to-use web page that allows your user to select from a list of predefined DIDs to use as their outbound caller ID.
Rather than having to memorize the desired phone numbers, you can give the DID a descriptive name such as "New York" if the location is important, or "Client Name" if the company name is important.
You can assign specific numbers to groups so you only see phone numbers applicable to your group.
business@brightwaylogisti
