Solved Given DN number cannot be used
David DeBrock
I am trying to create a new extension and getting the error "Given DN number cannot be used" when I try to use 2275 but was able to create 2274, 2276, and others. Why will it not allow 2275 as an extension?
A guess, you might have been using the extension for somethimg else, a IVR, Ring Group or Queue extension?
You could dial the number from another extension. If it seems to go somewhere, check the Activity Log to see where.
Hello @David DeBrock
Make sure that the specific extension number is not used anywhere else in the PBX. Extension numbers need to be unique between regular and system extensions
Thanks. Someone else had configured something that was conflicting.
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Bluebox Global
