GoIP4 with3cx
dwaik
i try to connect GoIP4 gateway but not success ,every time i see this message wrong cridental
i try it as gatway but not work,also i try as sip trunck but not work
04/17/2019 1:30:34 PM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from (goip ip ):5060 tid=231867125 Call-ID=2072470241@goip ip: REGISTER sip:3cx server SIP/2.0 Via: SIP/2.0/UDP goip ip :5060;branch=z9hG4bK231867125 Max-Forwards: 30 Contact: <sip:10000@goip ip:5060>;expires=0 To: "10000" <sip:10000@3cx ip> From: "10000" <sip:10000@3cx ip>;tag=1527214961 Call-ID: 2072470241@goip ip CSeq: 3 REGISTER Expires: 0 Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",nonce="414d53595cb7004a44:2581533699d73dfb71522bcd3d08bee5",uri="sip:3cx ip",response="2500168f1b92bee2a27f15ea66662e4c",algorithm=MD5 User-Agent: dble Content-Length: 0 ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
goip is the ip address of the gatway
3cx ip is the 3cx server ip
fransisco
