Google Bucket error with JSON file
FBW
Platinum Partner
We are changing backups from Google Drive to Google Bucket for all our customers. We have successfully configured all 3CX installations, but for 1 the JSON file is not invalid.
License is 16.0.7 Pro and is active.
Why is the JSON invalid while it works for other installations?
Hello FBW,
Could you provide a screenshot or error message that you're encountering with regards to the JSON file, so that we can better assist?
Here you have the screenshot.
The same file worked without any issues for at least 20 other installations.
Thank you for the screen shot.
Can you generate a new JSON file for the same service-account? It's an interesting one, there may be some correlation between the JSON file creation time and when you actually use the JSON file.
It's just a suspicion, but if you have generated a JSON file a few weeks ago, it may not let you use it.
Thanks for the hint of the time settings. The timezone of Windows was incorrect but the time was correctly set. As in 3CX the timezone was correctly configured, the time stamp of the log was 1 hour ahead. After changing timezone in Windows, I was able to connect the JSON file.
Reactions: NickD_3CX
sls1
