Google Contacts Sync
mac338
hello how can i sync my google contacts
You cannot. 3CX only supports Office 365 Contacts sync or On-prem Exchange. Not Google.
The only Google service supported is SSO.
Thanks. Is there perhaps a guide for this. Where do I have to enter which url. would help me a lot
This is the guide to create custom templates using the CRM Tool:
https://www.3cx.com/docs/crm-integration/
You will need to understand a bit about REST APIs.... If this is not your case, you should consider hiring someone to do this for you. There are many 3CX partners that can help with this for a fee.
NathanMitchell
