Solved Google speech-to-text stop working.
George@
Suddenly the transcript with google stopped working.
I tried to create new key with google but it no longer allow me to create IP based API key as show below URL.
https://www.3cx.com/docs/voicemail-transcription/
Now google's option is Jason format for API access.
Does anyone have been through this situation?
Hi George,
I just checked a Google Project I have going and the option seems to be there and the keys is created just fine.
Are you sure that the account you are using has the right permissions (if you are not using the owner account) and that billing is OK?
That was right. I mistakenly tried the similar operation from "speech to text" menu instead of “APIs & Services” > “Dashboard”
Thanks a lot
Reactions: NickD_3CX
intoxtech
