Grafana- outbound numbers
vaizal
Hello, we have set up integration with Grafana everything works however I have question. Is it possible to somehow export assigned outbound numbers and display them in Grafana? Or does CDR not store such information? Thanks a lot!
What Dashboard version are you using? Plugin or from the older ZIPs? What DB type? Which dashboard and panel? What exact PBX version?
Overall in the cdr export you have the field: source_presentation that should give the outbound number used.
Hello, tried with source_presentation field. It looks like it is empty since I get this result:
DB type: PostgreSQL
Using Plugin
Created new dashboard based on default (Extension Statistics dashboard)
PBX version: Version 20.0 Update 6 (Build 724 Release)
If you check the raw data in your DB, is that populated for you? It might be a later Update element.
ARKC
