Grandstream GRP2612 - Line Display / Appearance Issues
alpha-networks
Forum User
Hello everyone,
Doing my first 3CX deployment and getting the phones prepped. I've got everything operational from a call standpoint, but now I'm just trying to customize the phones a bit so that they look a bit cleaner. By default when you get a phone registered to the 3CX PBX, it seems to set the top Display as "EXT | NAME". Additionally it sets each line to the same settings "EXT | NAME". It looks kind of silly to have 3 things all saying the same thing. So I wanted to simply have the Company Name Displayed on the very top and then the Line1 Display simply have the extension or some other description. So on and so forth for other lines. The very top display seems to be changed via Acount 1 General Settings on the Phone Web UI. But when you edit it, it also changes Line1 to the same thing. So again, it looks kind of silly to have the exact same info listed twice. Its a very small business, only 2 phones. So we don't even need the 2nd line.
I've tried tweaking various options. The first image below is the closest I can get to what I want. Ideally I want the top display to say "Company Name" then Line 1 simply say "EXT". Even if i save the settings, after the phone reboots, it reverts to the second image.
13977
13978
Use a custom template
Thanks, I am seeing how to do custom templates and I am able to create a new one and successfully apply. But I'm not seeing in the txt file where you can change the top display and each line. Tried editing various parameters, no luck.
Any chance you can point out the 3 areas I would change in this file?
For each line, search for VPK or MPK in the file. The first two BLF are hard-coded as line key but you can change the label.
As for the top line, that's simply the account name which can be changed also at the beginning of the template content.
I appreciate the help by the way. I saw those area's, but still not able to create the desired effect. Only able to get the very top display and 1st line to display the same info. The VPKs don't seem to have line label field. Just Sucks because it looks silly to have the same exact things listed twice
Even if there was a way to just eliminate the top display would be helpful at this point.
Actually there's a good chance the VPK line key label is the Account Name configured. So the three fields should be the same.
So then there might not be a way to have different descriptions if thats the case?
natedog
