Grandstream GXP template ver. 99262 broken?
CFMtech
Hello 3CXer's I'm hoping someone can shed some light on an issue I'm running up against. We use custom templates to change some very basic functionality and I was going through and updating the newest Grandstream GXP template we have (grandstream.ph.xml ver. 99262) on our on-prem 3CX ver. 16.0.5.619 install and the changes werent taking affect. After digging into the template using the built in editor in 3CX I noticed there seems to be an issue at line 475
You can see the formatting (color coding) has changed after that line and I'm thinking there is an open parenthesis or something somewhere.
Here is the same section using my XML editor:
Am I missing something obvious here?
Thanks everyone, greatly appreciated!
Most recent version of the template is 102355. Update!
Interesting! Thats the most recent I show available to me:
No pending updates other than to x.x.x.622.
I wonder if I delete the xml file in there currently and reboot if that will prompt to download the newest(?) template.
Any chance you can tell me the published date on your version (102355)?
Thanks a lot!
Thanks a lot!
Actually, since you're on U5 before hotfix, you won't get the new templates.
Update to U6 to get them.
Reactions: CFMtech
Roger that. We can make that happen after hours this evening. Thanks for the direction.
Just so I'm not chasing a ghost here though, can you confirm your template doesn't have that break at/around line 475? Thanks @Frederick Marcoux you are an asset to this community.
Yes Frederick is experienced with Grandstream phones, this is like a third native language for him.
English, French, and Grandstream:)
Hehe
Just wanted to confirm that after updating to x.x.x.622 I was able to download the latest template and even though it is also showing that weird syntax issue this one IS working with our customization. I'm guessing either we accidentally broke something in the previous template or it had issues from Grandstream/3CX. Regardless we are good now. Thanks everyone.
SCarpenter@fifthavenue-la
