Grandstream GXP2170
kaivonderchromit
we´ve got a problem with our deployment from Grandstream 21xx-Series. Callbacks from list doesn´t work. All numbers come in in E164-format. With other phones (e.g. Snom D785, Grandstream GXP1780) there are no problems. Is it possible, that their is a problem in the template because the Grandstream says "Not in dialplan" - is there a "+" missing or not possible in dialplans in GXP2170?
3CX and phone templates are up-to-date and the whole environment is freshly deployed.
Thank you in advance
Kai
- What is your 3CX version running ?
- is 3CX on premise, cloud hosted?
- Do you use a VPN (only if cloud hosted) ?
- is it Windows, Debian, Pi hardware ?
- Are the phones local extensions on same LAN, or STUN,SBC if remote ?
- do you use up to date FW and 3CX standard templates? Which one version?
- Problem is on only on 21XX series ?
Hi aws2p,
the installation is:
  • 3CX version 16.0.910
  • it´s on prem
  • no VPN in use - all phones are located in the same ip-net
  • Debian-Version installed from iso image
  • FW is up-to-date 1.0.9.132
  • only standard templates used for deployment (we also tryed to delete the phone and reprovisioned it)
  • yes, problems only occure with GXP21xx series; GXP1780 worked out of the box
Kai
You have two options:
  • Mangle the CallerID on the trunk to eliminate the + sign.
  • Deploy a custom template you modify the dialplan on the Grandstream phones.
Like @cobaltit said, those are your options.
I had this issue and just went with the Caller ID manipulation.
Under each of your trunk, add a Caller ID rule for the pattern "+(.*)" to replace "\1". This should fix it for future calls.
[email protected].
