Solved Grandstream GXW42xx settings changed from analog phones?
Frank86
That's a question for Grandstream.
@Frank86
It's as cobaltit said, you might have to check with Grandstream for this one, 3CX does not configure anything else beyond the 3CX default template. All configuration that can be done via 3CX regarding devices is that which is available via the 3CX Management Console.
Reactions: Frank86
I disabled the option in the Grandstream's web interface. Just not sure whether the configuration is going to stick or whether 3CX will override and revert it to default (voice prompts enabled).
@Frank86
I can confirm that the 3CX template for the Grandstream GXW42XX does not initialize this parameter so whatever changes you make manually to the device should stick, or at least, won't get overwritten by 3CX.
@Frank86
Awesome. Thank you.
Reactions: NickD_3CX
Glad I could be of assistance! Please feel free to start a new thread should you need anything else!
Kayla Norris
