Grandstream HT802
Trevor Goode
Hello, I have been fighting with this faxing for a few days now. Setup the ATA from the 3CX website and it works with what i call local numbers, when i try to call a 855 or 800 number the fax machine comes back with this error.Digital Command Signal/Non-standard error, Job canceled. 035-705 Has anyone else seen this issue?Using a xerox WorkCentre 6605 I looked in the printer settings and cant see anything that needs changed.SIP trunk is with Flowroute. Thank you,
If faxing out works with local numbers but not toll-free you'll want to engage Flowroute. Trunking providers often handle TF calls differently and you can have results like what you've described.
In some cases, calls to toll free numbers, will fail, If the destination "objects" to your caller ID. It could be the format, or if it is blocked / sent as anonymous.
Support99
