Grandstream Template Update 11/09/2018
YonNomNom
Forum User
Hey just wanted to post the changes in the latest grandstream template so people don't have to update the template blind.
OLD - Version:80502
Code:
    <!-- Disable SIP NOTIFY Authentication. 0 - No, 1 - Yes. Default is 0 -->
    <!-- Number: 0,1 -->
    <!-- Mandatory -->
    <P4428>0</P4428>
NEW - Version:805023
<!-- Mandatory -->
<P4428>1</P4428>
I see it differently:upload_2018-9-10_17-46-25.png
But the change is the same like you mentioned - "<P4428>" is set to 1.
Did you modified something in the template?
megalmazan
